Battery Drain
(Topic created on: 29-09-2026 11:18 AM)
LJvV
Hi,
Has anyone else noticed the battery draining much quicker after going to beta One UI 9? Since doing the beta my device is draining with in 9 hours where I would previously on One UI 8.5 get 15 hours easily.
Thanks
1 REPLY 1
MartynaK
Beta Moderator
Beta Moderator
Hi @LJvV
Please restart your phone and check Battery usage to see whether a particular app is responsible. If the drain continues, send an error report through Samsung Members with system logs and a screenshot of the Battery usage screen so the team can investigate.
