Android auto Ford USB not supported error
(Topic created on: 08-04-2026 10:40 PM)
Elliottsix
Navigator
Since patch 8 I get Android auto Ford USB not supported error. But it will work regardless. Official cables in multiple cars. Anyone else having similar with theirs? 2017+ Ford Sync3 system
No issues besides it triggers not supported error on car screen 🤷‍♂️
1 REPLY 1
MartynaK
Beta Moderator
Beta Moderator
@Elliottsix,
This sounds like a compatibility/connection warning issue with Android Auto after the latest patch, even though the connection still works as expected.
Please report this as a bug through the Samsung Members app so the team can properly investigate it and collect logs from your device :hand-with-index-and-middle-fingers-crossed:.
